標(biāo)題: [求助] 求助:阿里云安裝的問題有誰遇到過嗎? [打印本頁]
作者: oasisoasis    時間: 2014-4-13 07:00     標(biāo)題: 求助:阿里云安裝的問題有誰遇到過嗎?
configure: error: Cannot use an external APR with the bundled APR-util
~/lanmp_laster# cat logs/wdcp_apache_install.log
checking for chosen layout... Apache
checking for working mkdir -p... yes
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
Configuring Apache Portable Runtime library ...
checking for APR... yes
  setting CC to "x86_64-linux-gnu-gcc"
  setting CPP to "x86_64-linux-gnu-gcc -E"
  setting CFLAGS to "  -pthread"
  setting CPPFLAGS to "  -DLINUX=2 -D_REENTRANT -D_GNU_SOURCE"
  setting LDFLAGS to " "
Configuring Apache Portable Runtime Utility library...
checking for APR-util... reconfig
