[求助] WDOS 安裝memcache
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking the maximum length of command line arguments... 98304
checking command to parse /usr/bin/nm -B output from cc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if cc supports -fno-rtti -fno-exceptions... no
checking for cc option to produce PIC... -fPIC
checking if cc PIC flag -fPIC works... yes
checking if cc static flag -static works... yes
checking if cc supports -c -o file.o... yes
checking whether the cc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking how to hardcode library paths into programs... immediate
checking whether to build shared libraries... yes
checking whether to build static libraries... no
creating libtool
config.status: creating config.h
config.status: config.h is unchanged
/bin/sh /tmp/memcache-2.2.5/libtool --mode=compile cc -I/www/wdlinux/nginx_php-5.2.17/include/php -I. -I/tmp/memcache-2.2.5 -DPHP_ATOM_INC -I/tmp/memcache-2.2.5/include -I/tmp/memcache-2.2.5/main -I/tmp/memcache-2.2.5 -I/www/wdlinux/nginx_php-5.2.17/include/php -I/www/wdlinux/nginx_php-5.2.17/include/php/main -I/www/wdlinux/nginx_php-5.2.17/include/php/TSRM -I/www/wdlinux/nginx_php-5.2.17/include/php/Zend -I/www/wdlinux/nginx_php-5.2.17/include/php/ext -I/www/wdlinux/nginx_php-5.2.17/include/php/ext/date/lib  -DHAVE_CONFIG_H  -g -O2   -c /tmp/memcache-2.2.5/memcache.c -o memcache.lo
mkdir .libs
cc -I/www/wdlinux/nginx_php-5.2.17/include/php -I. -I/tmp/memcache-2.2.5 -DPHP_ATOM_INC -I/tmp/memcache-2.2.5/include -I/tmp/memcache-2.2.5/main -I/tmp/memcache-2.2.5 -I/www/wdlinux/nginx_php-5.2.17/include/php -I/www/wdlinux/nginx_php-5.2.17/include/php/main -I/www/wdlinux/nginx_php-5.2.17/include/php/TSRM -I/www/wdlinux/nginx_php-5.2.17/include/php/Zend -I/www/wdlinux/nginx_php-5.2.17/include/php/ext -I/www/wdlinux/nginx_php-5.2.17/include/php/ext/date/lib -DHAVE_CONFIG_H -g -O2 -c /tmp/memcache-2.2.5/memcache.c  -fPIC -DPIC -o .libs/memcache.o
/tmp/memcache-2.2.5/memcache.c:34:18: error: zlib.h: No such file or directory
/tmp/memcache-2.2.5/memcache.c: In function ?.hp_memcache_init_globals?.
/tmp/memcache-2.2.5/memcache.c:255: error: ?._DEFAULT_COMPRESSION?.undeclared (first use in this function)
/tmp/memcache-2.2.5/memcache.c:255: error: (Each undeclared identifier is reported only once
/tmp/memcache-2.2.5/memcache.c:255: error: for each function it appears in.)
/tmp/memcache-2.2.5/memcache.c: In function ?.mc_compress?.
/tmp/memcache-2.2.5/memcache.c:839: error: ?._OK?.undeclared (first use in this function)
/tmp/memcache-2.2.5/memcache.c:846: error: ?._MEM_ERROR?.undeclared (first use in this function)
/tmp/memcache-2.2.5/memcache.c:849: error: ?._BUF_ERROR?.undeclared (first use in this function)
/tmp/memcache-2.2.5/memcache.c:852: error: ?._STREAM_ERROR?.undeclared (first use in this function)
/tmp/memcache-2.2.5/memcache.c: In function ?.mc_uncompress?.
/tmp/memcache-2.2.5/memcache.c:876: error: ?._BUF_ERROR?.undeclared (first use in this function)
/tmp/memcache-2.2.5/memcache.c:878: error: ?._OK?.undeclared (first use in this function)
make: *** [memcache.lo] Error 1
extension=memcache.so
Stopping httpd:                                            [FAILED]
Starting httpd: (98)Address already in use: make_sock: could not bind to address [::]:80
(98)Address already in use: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
Unable to open logs
                                                           [FAILED]
memcache install is OK
[root@wdOS ~]#
但是 WDCP 后臺顯示為 啟動
程序中無法啟用
重起一下系統(tǒng)
重起 也沒有啊
VABCV.net
32還是64,是哪個環(huán)境?
