本帖最后由 9zhmke 于 2013-4-17 01:00 編輯
我的意思是安裝 openssl 有什么錯(cuò)誤?
admin 發(fā)表于 2013-4-16 09:02
    首先感謝管理的關(guān)注。我安裝的是shopnc的商城程序,使用QQ登陸時(shí)出現(xiàn)502錯(cuò)誤,本貼的前面有用戶說換成高版本的1.0.1c可以解決這個(gè)問題。但不會(huì)安裝,按網(wǎng)上查來的資料總出錯(cuò),按我42樓的腳本根本無法運(yùn)行,連cd、dir、ls這類的命令都提示出錯(cuò),沒編過這腳本所以提出來請(qǐng)教示一下。
順便把安裝http2222_ssl.sh的log貼一下,麻煩看下對(duì)沒對(duì):
/www/web/default$ sh http2222_ssl.sh
#!/bin/bash
# mysql innodb install scripts
# Author:wdlinux
# Url http://www.szkyjg.com
if [ ! -f /usr/bin/gcc ];then
        yum install -y gcc gcc-c++ make autoconf libtool-ltdl-devel gd-devel freetype-devel libxml2-devel libjpeg-devel libpng-devel openssl-devel curl-devel patch libmcrypt-devel libmhash-devel ncurses-devel sudo bzip2
fi
if [ -d /root/lanmp/httpd-2.2.22 ];then
cd /root/lanmp/httpd-2.2.22
make clean
elif [ -f /root/lanmp/httpd-2.2.22.tar.gz ];then
cd /root/lanmp
tar zxvf httpd-2.2.22.tar.gz
cd httpd-2.2.22
else
cd /tmp
#wget -c http://dl.wdlinux.cn:5180/soft/httpd-2.2.22.tar.gz #手工下載放入/tmp
cd httpd-2.2.22
fi
IN_DIR="/www/wdlinux"
./configure --prefix=$IN_DIR/httpd-2.2.22 --enable-rewrite --enable-deflate --disable-userdir --enable-so --enable-expires --enable-headers --with-included-apr --with-apr=/usr --with-apr-util=/usr --enable-ssl --with-ssl=/usr
checking for chosen layout... Apache
checking for working mkdir -p... yes
Configuring Apache Portable Runtime library ...
configuring package in srclib/apr now
Configuring APR library
Platform: x86_64-unknown-linux-gnu
APR Version: 1.4.5
checking for chosen layout... apr
checking for gcc... gcc
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
Applying APR hints file rules for x86_64-unknown-linux-gnu
  setting CPPFLAGS to "-DLINUX=2"
  adding "-D_REENTRANT" to CPPFLAGS
  adding "-D_GNU_SOURCE" to CPPFLAGS
(Default will be unix)
checking whether make sets $(MAKE)... yes
checking how to run the C preprocessor... gcc -E
checking for gawk... gawk
checking for ranlib... ranlib
checking for a BSD-compatible install... /usr/bin/install -c
checking for rm... rm
checking for as... as
checking for cpp... cpp
checking for ar... ar
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking for library containing strerror... none required
checking whether system uses EBCDIC... no
performing libtool configuration...
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking how to recognize dependent libraries... pass_all
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... no
checking for g95... no
checking for xlf95... no
checking for f95... no
checking for fort... no
checking for ifort... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for ftn... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether  accepts -g... no
checking the maximum length of command line arguments... 98304
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... (cached) ar
checking for ranlib... (cached) ranlib
checking for strip... strip
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking how to hardcode library paths into programs... immediate
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
msde.cn
安裝的是shopnc的商城程序,使用QQ登陸時(shí)出現(xiàn)502錯(cuò)誤,本貼的前面有用戶說換成高版本的1.0.1c可以 ...
9zhmke 發(fā)表于 2013-4-17 00:53
    configure: creating libtool
checking for ld used by g++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
(cached) (cached) checking how to hardcode library paths into programs... immediate
appending configuration tag "F77" to libtool
Check for compiler flags...
checking whether the compiler provides atomic builtins... yes
checking whether to enable -D_LARGEFILE64_SOURCE... no
Checking for libraries...
checking for library containing gethostbyname... none required
checking for library containing gethostname... none required
checking for library containing socket... none required
checking for library containing crypt... -lcrypt
checking for main in -ltruerand... no
checking for library containing modf... none required
Checking for Threads...
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking for CFLAGS needed for pthreads... -pthread
  adding "-pthread" to CFLAGS
checking for LIBS needed for pthreads... -lpthread
  adding "-lpthread" to LIBS
checking for pthread.h... (cached) yes
checking whether pthread_getspecific takes two arguments... no
checking whether pthread_attr_getdetachstate takes one argument... no
checking for recursive mutex support... yes
checking for pthread_key_delete... yes
checking for pthread_rwlock_init... yes
checking for pthread_attr_setguardsize... yes
checking for pthread_yield... yes
checking for pthread_rwlock_t... yes
APR will use threads
checking for readdir in -lc_r... no
checking for gethostbyname in -lc_r... no
checking for gethostbyaddr in -lc_r... no
checking for getservbyname in -lc_r... no
checking for gethostbyname_r... yes
checking for gethostbyaddr_r... yes
checking for getservbyname_r... yes
checking for sigsuspend... yes
checking for sigwait... yes
checking for poll... yes
checking for kqueue... no
checking for port_create... no
checking for epoll support... yes
checking for epoll_create1 support... no
checking for dup3 support... no
checking for accept4 support... no
checking for SOCK_CLOEXEC support... no
checking for fdatasync... yes
checking for epoll_create1 support... (cached) no
checking for dup3 support... (cached) no
checking for accept4 support... (cached) no
checking for SOCK_CLOEXEC support... (cached) no
checking for getpwnam_r... yes
checking for getpwuid_r... yes
checking for getgrnam_r... yes
checking for getgrgid_r... yes
Checking for Shared Memory Support...
checking for library containing shm_open... -lrt
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking sys/ipc.h usability... yes
checking sys/ipc.h presence... yes
checking for sys/ipc.h... yes
checking sys/mutex.h usability... no
checking sys/mutex.h presence... no
checking for sys/mutex.h... no
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking sys/file.h usability... yes
checking sys/file.h presence... yes
checking for sys/file.h... yes
checking kernel/OS.h usability... no
checking kernel/OS.h presence... no
checking for kernel/OS.h... no
checking os2.h usability... no
checking os2.h presence... no
checking for os2.h... no
checking windows.h usability... no
checking windows.h presence... no
checking for windows.h... no
checking for mmap... yes
checking for munmap... yes
checking for shm_open... yes
checking for shm_unlink... yes
checking for shmget... yes
checking for shmat... yes
checking for shmdt... yes
checking for shmctl... yes
checking for create_area... no
checking for MAP_ANON in sys/mman.h... yes
checking for /dev/zero... yes
checking for mmap that can map /dev/zero... yes
decision on anonymous shared memory allocation method... 4.4BSD-style mmap() via MAP_ANON
decision on namebased memory allocation method... SysV IPC shmget()
checking for working alloca.h... yes
checking for alloca... yes
checking for calloc... yes
checking for setsid... yes
checking for isinf... yes
checking for isnan... yes
checking for getenv... yes
checking for putenv... yes
checking for setenv... yes
checking for unsetenv... yes
checking for writev... yes
checking for getifaddrs... yes
checking for utime... yes
checking for utimes... yes
checking for setrlimit... yes
checking for getrlimit... yes
checking for sendfilev in -lsendfile... no
checking for sendfile... yes
checking for send_file... no
checking for sendfilev... no
checking for sigaction... yes
checking whether sys_siglist is declared... yes
checking for fork... yes
checking for inet_addr... yes
checking for inet_network... yes
checking for _getch... no
checking for strerror_r... yes
checking for type of return code from strerror_r... pointer
checking for mmap... (cached) yes
checking for memmove... yes
checking for getpass... yes
checking for getpassphrase... no
checking for gmtime_r... yes
checking for localtime_r... yes
checking for mkstemp... yes
checking whether sigwait takes one argument... no
checking for ANSI C header files... (cached) yes
checking ByteOrder.h usability... no
checking ByteOrder.h presence... no
checking for ByteOrder.h... no
checking conio.h usability... no
checking conio.h presence... no
checking for conio.h... no
checking crypt.h usability... yes
checking crypt.h presence... yes
checking for crypt.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking dir.h usability... no
checking dir.h presence... no
checking for dir.h... no
checking dirent.h usability... yes
checking dirent.h presence... yes
checking for dirent.h... yes
checking dl.h usability... no
checking dl.h presence... no
checking for dl.h... no
checking for dlfcn.h... (cached) yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking grp.h usability... yes
checking grp.h presence... yes
checking for grp.h... yes
checking io.h usability... no
checking io.h presence... no
checking for io.h... no
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking mach-o/dyld.h usability... no
checking mach-o/dyld.h presence... no
checking for mach-o/dyld.h... no
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking for memory.h... (cached) yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking osreldate.h usability... no
checking osreldate.h presence... no
checking for osreldate.h... no
checking poll.h usability... yes
checking poll.h presence... yes
checking for poll.h... yes
checking process.h usability... no
checking process.h presence... no
checking for process.h... no
msde.cn
checking for ld ...
9zhmke 發(fā)表于 2013-4-17 00:55
    checking pwd.h usability... yes
checking pwd.h presence... yes
checking for pwd.h... yes
checking semaphore.h usability... yes
checking semaphore.h presence... yes
checking for semaphore.h... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for strings.h... (cached) yes
checking sysapi.h usability... no
checking sysapi.h presence... no
checking for sysapi.h... no
checking sysgtime.h usability... no
checking sysgtime.h presence... no
checking for sysgtime.h... no
checking termios.h usability... yes
checking termios.h presence... yes
checking for termios.h... yes
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking tpfeq.h usability... no
checking tpfeq.h presence... no
checking for tpfeq.h... no
checking tpfio.h usability... no
checking tpfio.h presence... no
checking for tpfio.h... no
checking for unistd.h... (cached) yes
checking unix.h usability... no
checking unix.h presence... no
checking for unix.h... no
checking for windows.h... (cached) no
checking winsock2.h usability... no
checking winsock2.h presence... no
checking for winsock2.h... no
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking for kernel/OS.h... (cached) no
checking net/errno.h usability... no
checking net/errno.h presence... no
checking for net/errno.h... no
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking netinet/sctp.h usability... no
checking netinet/sctp.h presence... no
checking for netinet/sctp.h... no
checking netinet/sctp_uio.h usability... no
checking netinet/sctp_uio.h presence... no
checking for netinet/sctp_uio.h... no
checking for sys/file.h... (cached) yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking for sys/mman.h... (cached) yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking sys/poll.h usability... yes
checking sys/poll.h presence... yes
checking for sys/poll.h... yes
checking sys/resource.h usability... yes
checking sys/resource.h presence... yes
checking for sys/resource.h... yes
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking sys/sem.h usability... yes
checking sys/sem.h presence... yes
checking for sys/sem.h... yes
checking sys/sendfile.h usability... yes
checking sys/sendfile.h presence... yes
checking for sys/sendfile.h... yes
checking sys/signal.h usability... yes
checking sys/signal.h presence... yes
checking for sys/signal.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/sockio.h usability... no
checking sys/sockio.h presence... no
checking for sys/sockio.h... no
checking for sys/stat.h... (cached) yes
checking sys/sysctl.h usability... yes
checking sys/sysctl.h presence... yes
checking for sys/sysctl.h... yes
checking sys/syslimits.h usability... no
checking sys/syslimits.h presence... no
checking for sys/syslimits.h... no
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking sys/uio.h usability... yes
checking sys/uio.h presence... yes
checking for sys/uio.h... yes
checking sys/un.h usability... yes
checking sys/un.h presence... yes
checking for sys/un.h... yes
checking sys/wait.h usability... yes
checking sys/wait.h presence... yes
checking for sys/wait.h... yes
checking for netinet/tcp.h... yes
checking for h_errno in netdb.h... yes
checking for off_t... yes
checking for pid_t... yes
checking for size_t... yes
checking for uid_t in sys/types.h... yes
checking for ssize_t... yes
checking for inline... inline
checking for an ANSI C-conforming const... yes
checking whether setpgrp takes no argument... yes
checking for socklen_t... yes
checking size of void*... 8
checking size of char... 1
checking size of int... 4
checking size of long... 8
checking size of short... 2
checking size of long long... 8
checking for INT64_C... yes
checking size of pid_t... 4
checking whether ssize_t and int are the same... no
checking whether ssize_t and long are the same... yes
checking whether size_t and unsigned int are the same... no
checking whether size_t and unsigned long are the same... yes
checking size of ssize_t... 8
checking which format to use for apr_ssize_t... %ld
checking size of size_t... 8
checking which format to use for apr_size_t... %lu
checking size of off_t... 8
checking which type to use for apr_off_t... off_t
checking size of ino_t... 8
configure: using ino_t for ino_t
checking whether byte ordering is bigendian... no
checking size of struct iovec... 16
checking for strnicmp... no
checking for strncasecmp... yes
checking for stricmp... no
checking for strcasecmp... yes
checking for strdup... yes
checking for strstr... yes
checking for memchr... yes
checking for strtol... yes
Checking for DSO...
checking for dlopen... no
checking for dlopen in -ldl... yes
msde.cn
回復(fù) 48# 9zhmke
      adding "-ldl" to LIBS
checking for dlsym... yes
Checking for Processes...
checking for waitpid... yes
checking for Variable Length Arrays... yes
checking struct rlimit... yes
Checking for Locking...
checking for semget... yes
checking for semctl... yes
checking for flock... yes
checking for semaphore.h... (cached) yes
checking OS.h usability... no
checking OS.h presence... no
checking for OS.h... no
checking for library containing sem_open... none required
checking for sem_close... yes
checking for sem_unlink... yes
checking for sem_post... yes
checking for sem_wait... yes
checking for create_sem... no
checking for working sem_open... yes
checking for union semun in sys/sem.h... no
checking for LOCK_EX in sys/file.h... yes
checking for F_SETLK in fcntl.h... yes
checking for SEM_UNDO in sys/sem.h... yes
checking for POLLIN in poll.h sys/poll.h... yes
checking for PTHREAD_PROCESS_SHARED in pthread.h... yes
checking for pthread_mutexattr_setpshared... yes
checking for working PROCESS_SHARED locks... yes
checking for robust cross-process mutex support... yes
decision on apr_lock implementation method... SysV IPC semget()
checking if fcntl returns EACCES when F_SETLK is already held... no
checking if all interprocess locks affect threads... no
checking if POSIX sems affect threads in the same process... no
checking if SysV sems affect threads in the same process... no
checking if fcntl locks affect threads in the same process... no
checking if flock locks affect threads in the same process... no
checking for entropy source... /dev/urandom
Checking for File Info Support...
checking for struct stat.st_blocks... yes
checking for struct stat.st_atimensec... no
checking for struct stat.st_ctimensec... no
checking for struct stat.st_mtimensec... no
checking for struct stat.st_atim.tv_nsec... yes
checking for struct stat.st_ctim.tv_nsec... yes
checking for struct stat.st_mtim.tv_nsec... yes
checking for struct stat.st_atime_n... no
checking for struct stat.st_ctime_n... no
checking for struct stat.st_mtime_n... no
checking for inode member of struct dirent... d_fileno
checking for file type member of struct dirent... d_type
Checking for OS UUID Support...
checking uuid.h usability... no
checking uuid.h presence... no
checking for uuid.h... no
checking uuid/uuid.h usability... no
checking uuid/uuid.h presence... no
checking for uuid/uuid.h... no
checking sys/uuid.h usability... no
checking sys/uuid.h presence... no
checking for sys/uuid.h... no
checking for library containing uuid_create... no
checking for library containing uuid_generate... no
checking for uuid_create... no
checking for uuid_generate... no
checking for os uuid usability... no
Checking for Time Support...
checking for struct tm.tm_gmtoff... yes
checking for struct tm.__tm_gmtoff... no
Checking for Networking support...
checking for type in_addr... yes
checking if fd == socket on this platform... yes
checking style of gethostbyname_r routine... glibc2
checking 3rd argument to the gethostbyname_r routines... char
checking style of getservbyname_r routine... glibc2
checking if TCP_NODELAY setting is inherited from listening sockets... yes
checking if O_NONBLOCK setting is inherited from listening sockets... no
checking whether TCP_NODELAY and TCP_CORK can both be enabled... yes
checking for TCP_CORK in netinet/tcp.h... yes
checking for TCP_NOPUSH in netinet/tcp.h... no
checking for SO_ACCEPTFILTER in sys/socket.h... no
checking whether SCTP is supported... no
checking for struct ip_mreq... yes
checking for set_h_errno... no
Checking for IPv6 Networking support...
checking for library containing getaddrinfo... none required
checking for library containing gai_strerror... none required
checking for library containing getnameinfo... none required
checking for gai_strerror... yes
checking for working getaddrinfo... yes
checking for negative error codes for getaddrinfo... yes
checking for working getnameinfo... yes
checking for sockaddr_in6... yes
checking for sockaddr_storage... yes
checking for working AI_ADDRCONFIG... yes
checking if APR supports IPv6... yes
checking langinfo.h usability... yes
checking langinfo.h presence... yes
checking for langinfo.h... yes
checking for nl_langinfo... yes
  setting have_unicode_fs to "0"
  setting apr_has_xthread_files to "0"
  setting apr_procattr_user_set_requires_password to "0"
  setting apr_thread_func to ""
  setting apr_has_user to "1"
Restore user-defined environment settings...
  restoring CPPFLAGS to ""
  setting EXTRA_CPPFLAGS to "-DLINUX=2 -D_REENTRANT -D_GNU_SOURCE"
  restoring CFLAGS to ""
  setting EXTRA_CFLAGS to "-g -O2 -pthread"
  restoring LDFLAGS to ""
  setting EXTRA_LDFLAGS to ""
  restoring LIBS to ""
  setting EXTRA_LIBS to "-lrt -lcrypt  -lpthread -ldl"
  restoring INCLUDES to ""
  setting EXTRA_INCLUDES to ""
config.status: creating Makefile
config.status: creating include/apr.h
config.status: creating build/apr_rules.mk
config.status: creating build/pkg/pkginfo
config.status: creating apr-1-config
config.status: creating apr.pc
config.status: creating test/Makefile
config.status: creating test/internal/Makefile
config.status: creating include/arch/unix/apr_private.h
config.status: executing default commands
config.status: include/apr.h is unchanged
config.status: include/arch/unix/apr_private.h is unchanged
srclib/apr configured properly
  setting CC to "gcc"
  setting CPP to "gcc -E"
  setting CFLAGS to " -g -O2 -pthread"
  setting CPPFLAGS to " -DLINUX=2 -D_REENTRANT -D_GNU_SOURCE"
  setting LDFLAGS to " "
Configuring Apache Portable Runtime Utility library...
configuring package in srclib/apr-util now
APR-util Version: 1.4.1
checking for chosen layout... apr-util
Applying apr-util hints file rules for x86_64-unknown-linux-gnu
checking for APR... yes
checking for ldap support...
checking for default DBM... sdbm (default)
checking for pg_config... no
checking libpq-fe.h usability... no
checking libpq-fe.h presence... no
checking for libpq-fe.h... no
checking postgresql/libpq-fe.h usability... no
checking postgresql/libpq-fe.h presence... no
checking for postgresql/libpq-fe.h... no
checking sqlite3.h usability... no
checking sqlite3.h presence... no
checking for sqlite3.h... no
checking sqlite.h usability... no
checking sqlite.h presence... no
checking for sqlite.h... no
checking sybdb.h usability... no
checking sybdb.h presence... no
checking for sybdb.h... no
checking freetds/sybdb.h usability... no
checking freetds/sybdb.h presence... no
checking for freetds/sybdb.h... no
checking for odbc_config... no
checking sql.h usability... no
checking sql.h presence... no
checking for sql.h... no
checking odbc/sql.h usability... no
checking odbc/sql.h presence... no
checking for odbc/sql.h... no
checking Expat 1.95.x... no
checking old Debian-packaged expat... no
checking old FreeBSD-packaged expat... no
checking Expat 1.0/1.1... no
  setting LDFLAGS to "-L/usr/local/lib"
  adding "-I/usr/local/include" to CPPFLAGS
checking Expat 1.95.x in /usr/local... no
  nulling LDFLAGS
  removed "-I/usr/local/include" from CPPFLAGS
msde.cn
checking for rm... /bin/rm
checking for pkg-config... /usr/bin/pkg-config
checking for rsync... /usr/bin/rsync
checking for lynx... no
checking for links... no
checking for elinks... no
checking sys/prctl.h usability... yes
checking sys/prctl.h presence... yes
checking for sys/prctl.h... yes
checking sys/processor.h usability... no
checking sys/processor.h presence... no
checking for sys/processor.h... no
checking for sys/wait.h that is POSIX.1 compatible... yes
checking for library containing sqrt... -lm
checking for getpwnam... yes
checking for getgrnam... yes
checking for initgroups... yes
checking for bindprocessor... no
checking for prctl... yes
checking for timegm... yes
checking for getpgid... yes
checking for void pointer length... no
checking for tm_gmtoff in struct tm... yes
checking whether to enable mod_authn_file... yes (default)
checking whether to enable mod_authn_dbm... no
checking whether to enable mod_authn_anon... no
checking whether to enable mod_authn_dbd... no
checking whether to enable mod_authn_default... yes (default)
checking whether to enable mod_authn_alias... no
checking whether to enable mod_authz_host... yes (default)
checking whether to enable mod_authz_groupfile... yes (default)
checking whether to enable mod_authz_user... yes (default)
checking whether to enable mod_authz_dbm... no
checking whether to enable mod_authz_owner... no
checking whether to enable mod_authnz_ldap... no
checking whether to enable mod_authz_default... yes (default)
checking whether to enable mod_auth_basic... yes (default)
checking whether to enable mod_auth_digest... no
checking whether to enable mod_isapi... no
checking whether to enable mod_file_cache... no
checking whether to enable mod_cache... no
checking whether to enable mod_disk_cache... no
checking whether to enable mod_mem_cache... no
checking whether to enable mod_dbd... no
checking whether to enable mod_bucketeer... no
checking whether to enable mod_dumpio... no
checking whether to enable mod_echo... no
checking whether to enable mod_example... no
checking whether to enable mod_case_filter... no
checking whether to enable mod_case_filter_in... no
checking whether to enable mod_reqtimeout... no
checking whether to enable mod_ext_filter... no
checking whether to enable mod_include... yes (default)
checking whether to enable mod_filter... yes (default)
checking whether to enable mod_substitute... no
checking whether to enable mod_charset_lite... no
checking whether to enable mod_deflate... checking dependencies
checking for zlib location... /usr
  adding "-lz" to LIBS
checking for zlib library... found
  forcing MOD_DEFLATE_LDADD to "-lz"
  removed "-lz" from LIBS
checking whether to enable mod_deflate... yes (default)
checking whether to enable mod_ldap... no
checking whether to enable mod_log_config... yes (default)
checking whether to enable mod_log_forensic... no
checking whether to enable mod_logio... no
checking whether to enable mod_env... yes (default)
checking whether to enable mod_mime_magic... no
checking whether to enable mod_cern_meta... no
checking whether to enable mod_expires... yes (default)
checking whether to enable mod_headers... yes (default)
checking whether to enable mod_ident... no
checking whether to enable mod_usertrack... no
checking whether to enable mod_unique_id... no
checking whether to enable mod_setenvif... yes (default)
checking whether to enable mod_version... yes (default)
checking whether to enable mod_proxy... no
checking whether to enable mod_proxy_connect... no
checking whether to enable mod_proxy_ftp... no
checking whether to enable mod_proxy_http... no
checking whether to enable mod_proxy_scgi... no
checking whether to enable mod_proxy_ajp... no
checking whether to enable mod_proxy_balancer... no
  adding "-I$(top_srcdir)/modules/proxy/../generators" to INCLUDES
checking whether to enable mod_ssl... checking dependencies
checking for SSL/TLS toolkit base... /usr
  adding "-I/usr/include" to CPPFLAGS
  adding "-I/usr/include" to INCLUDES
  adding "-L/usr/lib" to LDFLAGS
checking for OpenSSL version... checking openssl/opensslv.h usability... no
checking openssl/opensslv.h presence... no
checking for openssl/opensslv.h... no
checking openssl/ssl.h usability... no
checking openssl/ssl.h presence... no
checking for openssl/ssl.h... no
no OpenSSL headers found
configure: error: ...No recognized SSL/TLS toolkit detected
[ $? != 0 ] && exit
checking for SSL-C version... checking sslc.h usability... no
checking sslc.h presence... no
checking for sslc.h... no
no SSL-C headers found
msde.cn
求管理關(guān)注。求升級(jí)openssl成高版本的比如1.0.1c的腳本,安裝的shopnc的商城程序,使用QQ登陸時(shí)出現(xiàn)502錯(cuò)誤,本貼的前面有用戶說換成高版本的1.0.1c可以解決這個(gè)問題。但不會(huì)安裝,按網(wǎng)上查來的資料總出錯(cuò),按我42樓的腳本根本無法運(yùn)行,連cd、dir、ls這類的命令都提示出錯(cuò),沒編過這腳本所以只能提出來請(qǐng)教了。
msde.cn
yum install -y openssl openssl-devel
本帖最后由 9zhmke 于 2013-4-21 16:12 編輯
admin 發(fā)表于 2013-4-20 10:41
    老大,用這個(gè)提令升級(jí)提示正常完成,但重啟后查看版本顯示是OpenSSL 0.9.8e-fips-rhel5 01 Jul 2008,而且測試登陸同樣出錯(cuò),測試地址:http://msde.cn/index.php?act=login 右下方的QQ登錄。有沒其他辦法可以升級(jí)到1.0.1c或者1.0.1d呢?
騰迅要求除了dz論壇以外的其它軟件都使用高版本的接口才可以接上,低版本的只能接dz論壇了。
msde.cn
下載源碼編譯openssl
下載源碼編譯openssl
admin 發(fā)表于 2013-4-21 19:46
安裝的系統(tǒng)是wdos 64位 1.0 lanmp,下面這個(gè)腳本應(yīng)該就是源碼編譯吧?但是運(yùn)行出錯(cuò),應(yīng)該怎么改呢?
#!/bin/sh
# Author:wdlinux
set -v on
cd /tmp
#已手工解壓tar zxvf openssl-1.0.1d.tar.gz
cd openssl-1.0.1d
./config --prefix=/usr/local/openssl
./config --with-php-config=/www/wdlinux/php/bin/php-config
./configure  --with-openssl-dir=/usr/local/openssl --with-openssl
mv /usr/bin/openssl /usr/bin/openssl.OFF
mv /usr/include/openssl /usr/include/openssl.OFF
ln –s /usr/local/openssl/bin/openssl /usr/bin/openssl
ln –s /usr/local/openssl/include/openssl /usr/include/openssl
echo “/usr/local/sslb” >> /etc/ld.so.conf
ldconfig –v
openssl version –a
echo "Open ssl install is OK"
msde.cn
下載源碼編譯openssl
    可不可以付費(fèi)解決這個(gè)問題啊?
msde.cn
可以
本帖最后由 wobushihuairen 于 2013-5-14 19:40 編輯
我的也不能登陸502 Bad Gateway
nginx/1.0.15,提示這個(gè)。
我用的是shopnc的源碼,在后臺(tái)設(shè)置那qq互聯(lián)的那個(gè)驗(yàn)證代碼根本就寫不進(jìn)去,復(fù)制粘貼保存后刷新一下又成空白了,保存不了。
怎么辦啊?不知道還有沒有其它錯(cuò)誤
# sh lnmp_php_ssl_5217.sh
--2013-05-14 23:01:58--  http://www.openssl.org/source/openssl-1.0.1c.tar.gz
Resolving www.openssl.org... failed: Name or service not known.
wget: unable to resolve host address ?.ww.openssl.org?
tar (child): openssl-1.0.1c.tar.gz: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
lnmp_php_ssl_5217.sh: line 13: cd: openssl-1.0.1c: No such file or directory
lnmp_php_ssl_5217.sh: line 14: ./config: No such file or directory
回復(fù) 1# admin
nginx/1.0.15 的怎么設(shè)置
