gcc: Internal error: Killed (program cc1)
Please submit a full bug report.
See <http://bugzilla.redhat.com/bugzilla> for instructions.
make: *** [ext/fileinfo/libmagic/apprentice.lo] Error 1
make err
You have new mail in /var/spool/mail/root
請教該怎么辦?
升級報錯。。。∈。。!報錯如下:
  1. /root/php-5.3.17/ext/iconv/iconv.c: In function ‘zm_startup_miconv’:
  2. /root/php-5.3.17/ext/iconv/iconv.c:254: 錯誤:‘_libiconv_version’ 未聲明 (在此函數(shù)內(nèi)第一次使用)
  3. /root/php-5.3.17/ext/iconv/iconv.c:254: 錯誤:(即使在一個函數(shù)內(nèi)多次出現(xiàn),每個未聲明的標識符在其
  4. /root/php-5.3.17/ext/iconv/iconv.c:254: 錯誤:所在的函數(shù)內(nèi)只報告一次。)
  5. make: *** [ext/iconv/iconv.lo] 錯誤 1
  6. make err
請問老大,這個怎么解決?????
萬分感謝,阿門!。。。
云建站
要省錢,上匯誠:匯誠網(wǎng)
升級不成功,阿里云EMC系統(tǒng)是CentOS 6.3 64位
老大給的三個升級都提示OK了,phpinfo查看也正常 E6@Q$RWPYIHNZ{X%KME@66S.jpg ,但是打開網(wǎng)站后臺時候就提示 Zend Guard Run-time support missing!
敢不敢用 PHP.NET 的源啊 ,用你自己的源速度慘不忍睹
http://cn2.php.net/get/php-5.3.17.tar.gz/from/a/mirror
一次性升級結(jié)束,很順利!
感謝樓主
升級以后提示
virtual memory exhausted: Cannot allocate memory
請問如何解決!
慢慢來
升級后,打開網(wǎng)站后臺提示
Zend Optimizer not installed
This file was encoded by the Zend Guard. In order to run it, please install the Zend Optimizer (available without charge), version 3.0.0 or later.
Seeing this message instead of the website you expected?
This means that this webserver is not configured correctly. In order to view this website properly, please contact the website's system administrator/webmaster with the following message:
The component "Zend Optimizer" is not installed on the Web Server and therefore cannot service encoded files. Please download and install the Zend Optimizer (available without charge) on the Web Server.
Note: Zend Technologies cannot resolve issues related to this message appearing on websites not belonging to Zend Technologies.
What is the Zend Optimizer?
The Zend Optimizer is one of the most popular PHP plugins for performance-improvement, and has been available without charge, since the early days of PHP 4. It improves performance by scanning PHP's intermediate code and passing it through multiple Optimization Passes to replace inefficient code patterns with more efficient code blocks. The replaced code blocks perform exactly the same operations as the original code, only faster.
In addition to improving performance, the Zend Optimizer also enables PHP to transparently load files encoded by the Zend Guard.
The Zend Optimizer is a free product available for download from Zend Technologies. Zend Technologies also developed the PHP scripting engine, known as the Zend Engine.
淘省錢網(wǎng)
不行啊,報錯了
錯誤代碼
centos 5.6 32位 128內(nèi)存   不知道跟內(nèi)存小有沒有關(guān)系
See <URL:http://bugzilla.redhat.com/bugzilla&gt; for instructions.
make: *** [ext/date/lib/parse_date.lo] Error 1
make err
這個東西超級贊。!
按照老大的提示,已經(jīng)成功升級!
————————————————打一個小小的廣告哈:
中國萬維網(wǎng)
CPU雙核內(nèi)存1.5G硬盤100G空間帶寬5M獨享IP獨立1個機房北京多線機房 原價2200元,年底特價只需900元!
http://www.wanweiwang.cn/services/cloudhost/ttCloudServer.asp
wget: command not found.
提示問題。。
PHP 5.3.3 是嗎?
sh php_up53.sh
php-5.3.17/pear/install-pear.txt
php-5.3.17/pear/fetch.php
php-5.3.17/LICENSE
php-5.3.17/README.input_filter
make: *** No rule to make target `clean'.  Stop.
loading cache ./config.cache
checking for Cygwin environment... no
checking for mingw32 environment... no
checking for egrep... grep -E
checking for gcc... no
checking for cc... no
configure: error: no acceptable cc found in $PATH
configure err
[root@ZZ8800606062c29212 ~]#
請問如何處理的呢?
o
  1. /bin/sh /root/php-5.3.17/libtool --silent --preserve-dup-deps --mode=compile gcc  -Iext/dom/ -I/root/php-5.3.17/ext/dom/ -DPHP_ATOM_INC -I/root/php-5.3.17/include -I/root/php-5.3.17/main -I/root/php-5.3.17 -I/root/php-5.3.17/ext/date/lib -I/root/php-5.3.17/ext/ereg/regex -I/usr/include/libxml2 -I/usr/kerberos/include -I/usr/include/freetype2 -I/root/php-5.3.17/ext/mbstring/oniguruma -I/root/php-5.3.17/ext/mbstring/libmbfl -I/root/php-5.3.17/ext/mbstring/libmbfl/mbfl -I/www/wdlinux/mysql/include -I/root/php-5.3.17/ext/sqlite3/libsqlite -I/root/php-5.3.17/TSRM -I/root/php-5.3.17/Zend    -I/usr/include -g -O2 -fvisibility=hidden  -prefer-non-pic -c /root/php-5.3.17/ext/dom/userdatahandler.c -o ext/dom/userdatahandler.lo
  2. /bin/sh /root/php-5.3.17/libtool --silent --preserve-dup-deps --mode=compile gcc -I/root/php-5.3.17/ext/fileinfo/libmagic -Iext/fileinfo/ -I/root/php-5.3.17/ext/fileinfo/ -DPHP_ATOM_INC -I/root/php-5.3.17/include -I/root/php-5.3.17/main -I/root/php-5.3.17 -I/root/php-5.3.17/ext/date/lib -I/root/php-5.3.17/ext/ereg/regex -I/usr/include/libxml2 -I/usr/kerberos/include -I/usr/include/freetype2 -I/root/php-5.3.17/ext/mbstring/oniguruma -I/root/php-5.3.17/ext/mbstring/libmbfl -I/root/php-5.3.17/ext/mbstring/libmbfl/mbfl -I/www/wdlinux/mysql/include -I/root/php-5.3.17/ext/sqlite3/libsqlite -I/root/php-5.3.17/TSRM -I/root/php-5.3.17/Zend    -I/usr/include -g -O2 -fvisibility=hidden  -prefer-non-pic -c /root/php-5.3.17/ext/fileinfo/fileinfo.c -o ext/fileinfo/fileinfo.lo
  3. /bin/sh /root/php-5.3.17/libtool --silent --preserve-dup-deps --mode=compile gcc -I/root/php-5.3.17/ext/fileinfo/libmagic -Iext/fileinfo/ -I/root/php-5.3.17/ext/fileinfo/ -DPHP_ATOM_INC -I/root/php-5.3.17/include -I/root/php-5.3.17/main -I/root/php-5.3.17 -I/root/php-5.3.17/ext/date/lib -I/root/php-5.3.17/ext/ereg/regex -I/usr/include/libxml2 -I/usr/kerberos/include -I/usr/include/freetype2 -I/root/php-5.3.17/ext/mbstring/oniguruma -I/root/php-5.3.17/ext/mbstring/libmbfl -I/root/php-5.3.17/ext/mbstring/libmbfl/mbfl -I/www/wdlinux/mysql/include -I/root/php-5.3.17/ext/sqlite3/libsqlite -I/root/php-5.3.17/TSRM -I/root/php-5.3.17/Zend    -I/usr/include -g -O2 -fvisibility=hidden  -prefer-non-pic -c /root/php-5.3.17/ext/fileinfo/libmagic/apprentice.c -o ext/fileinfo/libmagic/apprentice.lo
  4. gcc: Internal error: Killed (program cc1)
  5. Please submit a full bug report.
  6. See <URL:http://bugzilla.redhat.com/bugzilla> for instructions.
  7. make: *** [ext/fileinfo/libmagic/apprentice.lo] Error 1
  8. make err
使用升級腳本后出錯了,不過后臺和網(wǎng)站還打得開。就是沒有php沒升級成功。怎么灰事?
