改進(jìn)更新如下:
- watchdog: set the LD_LIBRARY_PATH_64 variable on 64-bit systems (#4536)
- access-log: rollover rescheduling of alarm was not reliable (#4540, rep by mros2stf)
- ant-plugin: ant plugin has been moved to http://github.com/caucho/ant-plugin
- resin-cli: added jmx-list, jmx-set, jmx-call commands
- health: add OnStart, OnStop, OnRestart health predicates (#4257)
- scheduled-task: forward with param was causing NPE (#4530, rep by kenjrwalker)
- web-app: explicit web-app id="/" must override webapps/ROOT (#4531, rep by danielnuriyev)
- session: distributed sessions now allows jdbc as a backup (#3929, rep by jkriesten)
- servlet: fragment after/others ordering issues (#4523)
- cdi: abstract decorators were not properly handled (#4406)
- servlet: crlf escaping required for response headers because of rewrite-dispatch (#4525)
- jpa: when jta-data-source is null and JPA fails to start, allow web-app to start w/o error (#4491)
- watchdog: ResinMXBean now contains information about the last watchdog restart (#4257, rep by Tony Matson)
- jsp/el: MethodExpr invocation was not applied property (#4515)
- candi: @Produces on @Stateless with no interfaces (#4513)
- config: add <data-source> element support (#4487)
- jsp/el: BeanELResolver isValue/getValue mismatch (#4511, rep by Keith Fetterman)
- servlet: web-fragment <name> can have an "id" attribute (#4484)
- candi: ResinBeanContainer beans.xml @Alternatives issue (#4501)
- candi: ResinBeanContainer JPA/beans.xml ordering issues (#4502)
- session: add destroy-on-lru flag to session-config to call SessionListener.destroy on a LRU even when session is persisted (#4504)
- servlet: CauchoRequestWrapper updates for MockHttpServletRequest compatibility (#4509)
- jstl: c:set not properly returning XML for validation (#4492)
- ejb: stateless generics on interface superclass (#4512, rep by andreaskaltenbach)
- ejb: stateless generics on method argument (#4514)
- config: <class-loader> has automatic priority (#4500)
- watchdog: signal status reporting was showing exit 0 for signals (#4508)
- hessian: send-collection-type should always send java.util types (#4489, rep by Keith Fetterman)
- ioc: resin:message not properly initialized (#4496, rep by Keith Fetterman)
- ioc: env-entry does not use EL - doc update (#4516, rep by mnsh)
- ejb: ejb-ee jar with <entity> should be skipped w/o fatal error (#4503, rep by Rick Mann)
下載 Resin 4.0.18
http://www.caucho.com/download/
[我的Linux,讓Linux更易用]
CentOS精簡版,集成lamp,lnmp版,
wdcp,
wdcdn,
wddns,
一鍵安裝包,集群負(fù)載均衡LVS,智能DNS/CDN,性能優(yōu)化
本文連接:
http://www.szkyjg.com/old/node/649
