ISPConfig
按教程安裝到輸入mysql密碼這里 直接按回車顯示錯(cuò)誤
歡迎轉(zhuǎn)載,但請(qǐng)保留此信息
本文連接:http://www.szkyjg.com/old/node/139
ispconfig 使用方法
大哥們,在哪里可以找到ispconfig的使用方法啊,我用測(cè)試機(jī)做了多次都 沒(méi)有成功,還請(qǐng)指點(diǎn)一二啊
沒(méi)有成功,將你的問(wèn)題發(fā)上來(lái) 至于使用方法,不知你指哪些,是
至于使用方法,不知你指哪些,是ispconfig面板里的操作?或者你上網(wǎng)搜索下或去官網(wǎng)看下
具體是什么錯(cuò)誤
具體是什么錯(cuò)誤
我也遇到同樣問(wèn)題
The latest information about MySQL is available on the web at
http://www.mysql.com
Please consult the MySQL manual section: 'Problems running mysql_install_db',
and the manual section that describes problems on your OS.
Another information source is the MySQL email archive.
Please check all of the above before mailing us!
And if you do mail us, you MUST use the /usr/bin/mysqlbug script!
                                                           [FAILED]
Starting httpd: httpd: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1 for ServerName
(98)Address already in use: make_sock: could not bind to address [::]:80
(98)Address already in use: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
Unable to open logs
                                                           [FAILED]
error reading information on service dovecot: No such file or directory
ispconfig3_install.sh.txt: line 23: /etc/init.d/dovecot: No such file or directory
error reading information on service sendmail: No such file or directory
ispconfig3_install.sh.txt: line 26: /etc/init.d/sendmail: No such file or directory
Starting postfix:                                          [  OK  ]
NOTE: RUNNING ALL PARTS OF THIS SCRIPT IS RECOMMENDED FOR ALL MySQL
      SERVERS IN PRODUCTION USE!  PLEASE READ EACH STEP CAREFULLY!
In order to log into MySQL to secure it, we'll need the current
password for the root user.  If you've just installed MySQL, and
you haven't set the root password yet, the password will be blank,
so you should just press enter here.
Enter current password for root (enter for none):
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
80被占用,系統(tǒng)中可能還運(yùn)行了其它的apache mysq
mysql沒(méi)安裝成功或是沒(méi)啟動(dòng)成功
