[root@soft bind]# sbin/rndc status rndc: connect failed: 127.0.0.1#953: connection refused
我先不說我系統(tǒng)問題。 我換了 好幾個服務(wù)器 都是 centos 5 的 32位的 都出現(xiàn)這個問題。squid 和lnmp 都好。 就是named 啟動 。 啟動時啟動起來了。 就是 有時候十幾分鐘自動關(guān)閉。 有時候幾分鐘就會關(guān)閉。 群里面 有好有個朋友都遇到這樣的問題。 老大應(yīng)該重視一下,觀察了日志也沒什么問題。。。。
[root@soft bind]# cat /var/log/messages
May 28 04:02:05 soft syslogd 1.4.1: restart.
May 28 08:58:12 soft named[29944]: starting BIND 9.8.0-P1 -u named -c /www/wdlinux/bind/etc/named.conf
May 28 08:58:12 soft named[29944]: built with '--prefix=/www/wdlinux/bind-9.8.0' '--with-dlz-mysql=/www/wdlinux/mysql' '--enable-largefile' '--enable-threads' '--with-openssl=yes' '--disable-openssl-version-check'
May 28 08:58:12 soft named[29944]: adjusted limit on open files from 1024 to 1048576
May 28 08:58:12 soft named[29944]: found 4 CPUs, using 4 worker threads
May 28 08:58:12 soft named[29944]: using up to 4096 sockets
May 28 08:58:12 soft named[29944]: loading configuration from '/www/wdlinux/bind/etc/named.conf'
May 28 08:58:12 soft named[29944]: reading built-in trusted keys from file '/www/wdlinux/bind-9.8.0/etc/bind.keys'
May 28 08:58:12 soft named[29944]: using default UDP/IPv4 port range: [1024, 65535]
May 28 08:58:12 soft named[29944]: using default UDP/IPv6 port range: [1024, 65535]
May 28 08:58:12 soft named[29944]: listening on IPv4 interface lo, 127.0.0.1#53
May 28 08:58:12 soft named[29944]: listening on IPv4 interface eth0, 58.61.160.173#53
May 28 08:58:12 soft named[29944]: generating session key for dynamic DNS
May 28 08:58:12 soft named[29944]: Loading 'Mysql zone' using driver mysql
May 28 08:58:12 soft named[29944]: set up managed keys zone for view telecom_view, file '7e3aab9aa2c03cd5429ec591242e463f22800c6bf8578dd49106508df0ce679a.mkeys'
May 28 08:58:12 soft named[29944]: set up managed keys zone for view any_view, file 'a0643b5fdac56b4f65bbba3c34eac22f30548badc71c9f26ddf9a1d6d37789b4.mkeys'
May 28 08:58:12 soft named[29944]: command channel listening on 127.0.0.1#953
May 28 08:58:12 soft named[29944]: managed-keys-zone ./IN/telecom_view: loaded serial 0
May 28 08:58:12 soft named[29944]: managed-keys-zone ./IN/any_view: loaded serial 0
May 28 08:58:12 soft named[29944]: running
[我的Linux,讓Linux更易用]
CentOS精簡版,集成lamp,lnmp版,
wdcp,
wdcdn,
wddns,
一鍵安裝包,集群負(fù)載均衡LVS,智能DNS/CDN,性能優(yōu)化
本文連接:
http://www.szkyjg.com/old/node/712
做了DNS轉(zhuǎn)發(fā)后是有這個問題,目前還在測試和查找原因
還有,這個是DNS,不是CDN
